Flickering label tileset since 1.121.0
Hi!
Since updating to 1.121 (I skipped directly to 1.122 but could not reproduce this with 1.120 or prior) I have a label tileset that keeps flickering.
Is there something wrong with my data? (I haven’t changed this data since ages though)
Here’s a sandcastle with the tileset in action, try zooming or moving around Switzerland and you should see black flickering all over the place.
Hi @pakb ,
Thanks for your note and welcome to the Cesium community.
This does look like a bug that should be investigated. Thank you for providing a clear sandcastle that demonstrates the issue. Since you mentioned that you data has not changed, it seems likely this a problem with the library and not with your data. I went ahead and made a bug report with the info you shared here in the Cesium repo Flickering label tileset since 1.121 · Issue #12287 · CesiumGS/cesium · GitHub. Feel free to follow the issue or add more useful information.
Thanks again and we hope somebody form the community or Cesium team can find the root cause and make a fix soon.
Luke
Thanks! Then I’ll add myself to the subscribers of the GitHub issue :wink:
