I would like, when the user hits a button, to have the camera fly to a particular entity and then track it. Is there a way to do this using existing functions or do I need to implement it myself using a CallbackProperty?
viewer.flyTo returns a promise that is resolved when the camera flight is finished, so you can set the tracked entity after the flight. Here is a code example:
var viewer = new Cesium.Viewer(‘cesiumContainer’, {timeline : false, animation : false});
var pinBuilder = new Cesium.PinBuilder();
var bluePin = viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(-75.170726, 39.9208667),
billboard : {
image : pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 48).toDataURL(),
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
Sandcastle.addToolbarButton(‘Track Pin’, function() {
viewer.flyTo(bluePin)
.then(function() {
viewer.trackedEntity = bluePin;
Hannah
Thanks, Hannah … I didn’t realize that flyTo returned a promise. That’s nice.
Now the problem that I’m having is two-fold:
- It appears that
flyTodoes not use the object’sviewFromproperty the same way thattrackedEntitydoes, soflyTotakes the camera to one location and then pops to theviewFromlocation at the end - For similar reasons,
flyTodoes not move the camera orientation to that which it needs to be when it arrives at theviewFromlocation. In my case, the camera smoothly tips up during theflyToand then snaps back down whentrackedEntityis set.
Any advice? I could try toflyToa location, but that’s tricky since the object is moving.
Hmm, sorry, I don’t have any good suggestions. It’s a bit of a complicated problem, especially if the object is moving.
This is something that has been on our roadmap for a little while, but I created an issue so we know that it is something that has been asked for from our users:
Hannah
Thanks, Hannah!
I’m having this issue as well.
I wrote the following code to zoom in to a certain distance and then track the “plane” as it flys it’s intended route. The offset works well then BLIP it blinks to the super close up of the plane moving along it’s route.
I want the tracking but keep the original camera distance.
viewer.flyTo(plane,{
offset: new Cesium.HeadingPitchRange(0, -Cesium.Math.PI_OVER_FOUR, 150000)
}).then(function(){
viewer.trackedEntity = plane;
viewer.clock.multiplier = 10;
viewer.clock.shouldAnimate = true;
Hannah, I’ll second that motion: “something that has been asked for from our users”. default behavior is less than ideal. I tried a similar solution to Gerry’s, but the results were disappointing.
PS. I’m looking forward to release 1.30 tomorrow! I can’t believe its February already!
Hey, Im having the same issue, how did it end? its been a while now
