I am using the default geocoder.
I would like to catch the event that fires when the user enters an address, and presses the search button.
Ideally, I would also like to reduce the amount of zooming in that the geocoder does.
I get this error by calling the code below:
Uncaught TypeError: Cannot read property ‘addEventListener’ of null
This is the code I am calling (winging it!)
var searchButton = document.getElementById(‘cesium-geocoder-searchButton’); // searchButton is undefined
searchButton.addEventListener(‘click’, showSearchInput, false);
Obviously, this doesn’t work…
How do I catch the click event on the search button?
I already have a click handler in my code…is there a way to determine that I am clicking on the search button?
I want to show a point, and the address that the user entered in the search box, when the user presses on the search button.
I also would like control of the amount of zooming in when the geocoder does the flight.
1.38, mac, chrome
Thank you!
