I am trying to display GeoJSON data using the CesiumWidget. I have the following code which uses the GeoJSON sandcastle example as a starting point. When running the code the following console statements are printed in the console.
# of entities loaded = 182
Datasource added successfully
Display updated successfully
While looking at the forum for help, I found older posts which indicated that I needed to update the datsourceDisplay. Which I am know doing.
Currently the code does not generate any error message or exceptions however, entities are not being rendered. Does anybody know what I am doing wrong?
Thanks in advance
Jerry
P.S. Sandcastle is a great tool!!
var widget = new Cesium.CesiumWidget('cesiumContainer');
var dataSourceCollection = new Cesium.DataSourceCollection();
var datasource = new Cesium.GeoJsonDataSource();
var dataSourceDisplay = new Cesium.DataSourceDisplay({
scene: widget.scene,
dataSourceCollection : dataSourceCollection
//Load the document into the data source and then set custom graphics
datasource.loadUrl('../../SampleData/ne_10m_us_states.topojson').then(function() {
//Get the array of entities
var entities = datasource.entities.entities;
console.warn('# of entities loaded = ' + entities.length);
var colorHash = {};
for (var i = 0; i < entities.length; i++) {
//For each entity, create a random color based on the state name.
//Some states have multiple entities, so we store the color in a
//hash so that we use the same color for the entire state.
var entity = entities[i];
var name = entity.name;
var color = colorHash[name];
if (!color) {
color = Cesium.Color.fromRandom({
alpha : 1.0
colorHash[name] = color;
//Set the polygon material to our random color.
entity.polygon.material = Cesium.ColorMaterialProperty.fromColor(color);
//Outline each polygon in black.
entity.polygon.outlineColor = new Cesium.ConstantProperty(Cesium.Color.BLACK);
//Extrude the polygon based on the state's population. Each entity
//stores the properties for the GeoJSON feature it was created from
//Since the population is a huge number, we divide by 50.
entity.polygon.extrudedHeight = new Cesium.ConstantProperty(entity.properties.Population / 50.0);
dataSourceCollection.add(datasource);
console.warn('Datasource added successfully');
dataSourceDisplay.update(new Cesium.JulianDate());
console.warn('Display updated successfully');
Thanks in advance
Jerry
var colorHash = {};
if (!color) {
alpha : 1.0
