I tried to draw the entity from geojson , linestring but came up with the
following error. The feature count is approximate 7000.
-----------Error Message--------------------
TypeError: Failed to execute ‘shaderSource’ on ‘WebGLRenderingContext’: parameter 1 is not of type ‘WebGLShader’.
at f (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:497:12800)
at y (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:497:15937)
at d._bind (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:497:16952)
at V (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:522:21796)
at k.draw (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:522:25431)
at n.execute (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:496:17756)
at d.executeCopyColor (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:536:2495)
at tt (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:541:17467)
at it (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:541:18658)
at we.render (http://192.168.1.111/c1t1/Build/Cesium/Cesium.js:541:26600)
var promise = Cesium.GeoJsonDataSource.load(’…/Specs/Data/KML/tn1_road_84.geojson’);
promise.then(function(dataSource) {
viewer.dataSources.add(dataSource,
camera: viewer.scene.camera,
canvas: viewer.scene.canvas,
clampToGround: false
for (var i = 0; i < entities.length; i++) {
var entity = entities[i];
entity.polyline.material = Cesium.Color.WHITE;
entity.polyline.width = 10;
I would like to test the performance in 3D with pipeline data, maybe more than 7k or more.
Cesium: 1.41
OS: Win7 x64
**Browser: Chrome, **Version 63.0.3239.132 (Official Build) (64-bit)
