I want to render an image of varying opacity draped onto the globe. The image is stretched/skewed such that the four corners are fixed to four known coordinates on the globe. Mapbox supports this feature on their 2D map (https://docs.mapbox.com/mapbox-gl-js/example/image-on-a-map/), and I think they do it by splitting the image into two triangles and fitting those separately.
I’ve spent a little time looking into the Cesium APIs, but I didn’t see a clean way to do this. The best idea I had was to distort the image myself in a canvas, then apply that as an ImageMaterial to some geometry, but that’s likely incorrect when accounting for the ellipsoid shape of the globe.
No example available.
The application I am building includes georeferenced images, which are placed on the map and fit to specific coordinates. I need a way to display those images properly fitted, draped over terrain, with some level of opacity.
Cesium 1.63, Chrome 78.0.3904.97, macOS Version 10.14.6
