I’d like to be able to add a trapezoid (which I believe the only way would be through the polygon object, correct me if I am wrong). But my material will always appear towards the initial view. How can I warp my material corners to fit exactly the points of its container?
Not needed
I need it to georeference images on a map
1.62 - iOS Mojave - Google chrome
