Hello, I am having a problem where I need a polygon with an image material that distorts to always fit. Currently if you have a polygon (with lets say 4 points for simplicity) and the image size ratio doesn’t match up with the polygon’s points, the image will be cut off.
(this example below uses the image rotation to throw it out of the correct proportions to fit inside but it’s still the same problem. is there a way for it to just distort to fit in there even though it would have to squish inside?)
let viewer = new Cesium.Viewer('cesiumContainer');
viewer.entities.add(new Cesium.Entity({
polygon:
hierarchy:
positions: [{ x: -5099561.112354739, y: 471018.36210765265, z: -3788996.464597908 },
{ x: -5099564.409358333, y: 470982.66516832606, z: -3788996.4645979083 },
{ x: -5099581.806381637, y: 470984.2719126955, z: -3788973.0084019853 },
{ x: -5099578.5093667945, y: 471019.9689738013, z: -3788973.0084019853 }]
material: "https://images2.minutemediacdn.com/image/upload/c_crop,h_1414,w_2101,x_20,y_0/v1565279671/shape/mentalfloss/578211-gettyimages-542930526.jpg?itok=Nj49PDxW",
stRotation: Cesium.Math.toRadians(45),
I have images I would like to display on the terrain and be able to distort them to fit the terrain imagery in case they aren’t perfectly aligning.
Currently if I shift a point in my polygon to a new position with the image material in place, the image just crops off.
Note:
I cannot use a rectangle object as whatever I’m trying to align with my image may not be rectangular.
Cesium JS 1.66
Windows 10
Chrome
