I drew line with callback property on mouse move and set “clampToGround” property as true. And it works fine. It draws correctly on point cloud.
But I am going to get all points from this line.
Exactly I am going to get all points from “activeShape” below code. Could anyone teach me about it?
Best
if (Cesium.defined(cart3PointsArray[0])) {
if (activeShapePoints.length === 0) {
floatingPoint = createClampedToTerrainPoint(window.MAIN_CESIUM_VIEWER, cart3PointsArray[0]);
activeShapePoints.push(cart3PointsArray[0]);
var dynamicPositions = new Cesium.CallbackProperty(function () {
return activeShapePoints;
}, false);
activeShape = drawPolyShape(window.MAIN_CESIUM_VIEWER, dynamicPositions, “line”, colorRef.current);
for (let i = 0; i < cart3PointsArray.length; i++) {
if (Cesium.defined(floatingPoint)) {
if (Cesium.defined(cart3PointsArray[i])) {
floatingPoint.position.setValue(cart3PointsArray[i]);
activeShapePoints.pop();
activeShapePoints.push(cart3PointsArray[i]);
Version 1.62 latest version
