Get altitude at lat long
Enjoying Cesium for Unreal so far :slight_smile:
I have some (lat, long, alt) points but the alt points are a little noisy. Is there a way to get the height of the terrain? Ideally I’d like to draw on the tiles like:
but just getting access to the height of the terrain would suffice.
Is this possible yet in Cesium for Unreal?
Hi @nhapeman,
Great question. We are currently working on a direct way of querying the height of terrain given lat/long.
However, given your use case, a decal component might be well suited for your use case of drawing on top of the terrain.
If you do need to get the height in the meantime, you could try doing a line trace to the world terrain object and use the Z value. The only issue might be if the fully refined tile is not loaded in when doing the trace, in which case the resulting terrain altitude will either end up being an overestimate or underestimate.
You could work around this by a) doing a new line trace when the camera gets close to the area and more detailed terrain gets loaded in, and adjusting the height of your Unreal object, or b) Temporarily setting the Maximum Screen Space Error in the tileset to a small number, and using the fully-loaded terrain to do the line trace (for example, using a small max SSE at editor time, then once the heights are determined, the value can be set back to normal).
Thanks! I did get ray tracing to work. Had some issues with ray tracing not working when the camera wasn’t looking in the direction I wanted to ray trace but got around it with a minimal caching solution. Should be a good enough solution to last to an update with legit terrain height grabbing.
Do you guys have a release date for the elevation query?
Hi @xuelong , do you have any updates regarding this feature?
any progress on this quite useful feature?
Best
Andreas
I agree it is very useful! But we don’t have an update on it at this time.
Just to give an update, as of Cesium for Unreal v2.9.0, you can now use the asynchronous SampleHeightMostDetailed function to query the height on a tileset, at a given longitude / latitude position. This is available in both Blueprints and C++. Remember that this height is returned in meters above the WGS84 ellipsoid!
You can find a Blueprints example in this PR comment: Add Unreal API for terrain height querying by csciguy8 · Pull Request #1421 · CesiumGS/cesium-unreal · GitHub
is this functionality available for hte latest version of cesium ?
Hi @Mayamin_Raha, welcome to the community!
Yes, see my comment right above your post. We added this function to the plugin last year and it continues to be a feature to this day. Let us know if you run into any issues or need further support. Thanks!
Hello, Thank you I am using Cesium 2.13.3, and using C++ code to use SampleHeightMOstdetailed function but it seems to be unrecognized. Can you tell me which file of cesium has definition of this function and I could check it by myself ? I checked Cesiumgeoreference.h and it did not have the fucntion definition for it. However, it does work in level blueprint editor but provides an elevation value below cesium tile surface at all times.
@Mayamin_Raha it is a method on ACesium3DTileset and the declaration is found in Cesium3DTileset.h. The documentation for it is here:
I need to sample height multiple times per frame and this is function is very costly, like i have cars moving on cesium terrain and for 4 wheels i need to sample height so that on cliffs etc., the movement remains realistic, so for thousand cars being driven on terrain, and 4 points on each car, total become 4000, and sampling 4k points per frame is dropping frames. and i cant even run it on separate thread as it i guess runs on main thread only
Hey @Saad_Abbas, looks like you posted this separately and that topic now has a response! Please let us know on that topic if that information was helpful!
