Is there any way to get the cesium ion usage history using the cesium ion rest api?
I want to get usage information for specific time range.
I appreciate any help you can provide.
At this time we do not offer a public API to query usage data.
Can you provide us some more context about your use case? Is there a reason why using the time range feature in the UI isn’t working for you? That will help us better prioritize this functionality.
Hi @mdc9001
Thanks for your reply.
Yeah. The Cesium ion usage UI is working for me.
But I need to get this information for my application. I want to know how often geocode, Bing map, and Google photorealistic tileset are used in my application.
Is there any api for getting the number of Google photorealistic tileset usage?
Hi
At this time there is no API available for checking any usage statistics.
You can filter by access token on the Usage page in the UI. If you create a token unique to your application that will let you see the usage for just your application.
Thank you for your reply.
How can I see usage for my application using access token?
