Get czml building at certain height
I want to get 3D buildings on top of the terrain for which I have the Elevation data for the buildings.
I wrote czml code like following:
  "id": "1",
 "description": "Building Height:24.600(m)",
"polygon": {
       "extrudedHeight": {
                "number": 24.600
         "outline": {
               "boolean": true
         "outlineColor": {
                  "rgba": [0,
                0,
                 0,
                 255]
         "material": {
              "solidColor": {
                    "color": {
                                 "rgba": [255,
                              0,
                                 0,
                                 163]
         "positions": {
             "cartographicDegrees": [78.39464257000003,
                 17.477616975000046,
                527.72000000000116,
                78.394779279000034,
                17.477647653000076,
                527.72000000000116,
                78.394808867000052,
                17.477550339000061,
                527.72000000000116,
                78.39466662600006,
                 17.477517146000082,
                527.72000000000116,
                78.39464257000003,
                 17.477616975000046,
                527.72000000000116]
But I am not getting the building at given cartographic altitude(527.72). The building is still sticking to the ellipsoid.
I have tried “polygon.height”, “polygon.perPositionHeight” properties but didn’t find correct way.
Help needed !
You need to set both the height and extrudedHeight options. Try something like this:
“extrudedHeight”: 24.600 + 527.72,
“height”: 527.72,
And then for your positions.cartographicDegrees, just use the longitude and latitude coordinates.
Hannah
Thanks Hannah… That worked. But I would like to say that it seems a bit illogical in itself. Documentation also is confusing for this task.
Following lines worked,
“extrudedHeight”:{“number”:552.32},
“height”:{“number”:527.72},
Thanks, I submitted a fix for the documentation here: https://github.com/AnalyticalGraphicsInc/cesium/pull/3443
-Hannah
