the problem I am having is the building moves based upon orientation. I expected it to stay at that location but if you pan or tilt the camera it goes sliding off. Am I missing a few properties or am I not setting something right?
I assume you have terrain enabled? Currently most data types in Cesium, including models, don’t take terrain into account. The 0 height you specify is in reference to the ellipsoid, not the terrain ground. So the building is being drawn partially underground but not obscured, hence the parallax effect. This will be addressed in a near term release of Cesium. The only workaround for now would be to bake the height of the building into your CZML file to already take terrain into account.
