hello everyone. for my project I need to cut some part of the city and use it in Revit. do you have any suggestio that we can cut some part of the mesh from google realistic photo and export in to revit?
@kousha I believe doing so would be in violation of the Google Map Tiles API policies, particularly this section:
Applications using the Map Tiles API are bound by the terms of your Agreement with Google. Subject to the terms of your Agreement, you must not pre-fetch, index, store, or cache any Content except under the limited conditions stated in the terms.
Specifically, applications should use Map Tiles API for map visualizations. You may not use Map Tiles API for any non-visualization use cases, such as:
- Image analysis
- Machine interpretation
- Object detection or identification
- Geodata extraction or resale
- Offline uses, including for any of the above
As such, there’s no way to do this in Cesium for Unreal.
