@agallegos
I came across this post when searching about Raycasting in Cesium.
What is the best way to get a raycast hit point, because using ScreenToWorldPoint will always return 0, 0, 0 for the origin. I guess this is expected because the camera will always be rebased to the new axes.
Thanks
Hi @sonny_unity,
It sounds like you’re asking about raycasting in Unity instead of Unreal, so I’ve moved your post to a new topic in the Cesium for Unity category.
I’m looking into your query and I’ll let you know what I find out!
-Alex
Hi @sonny_unity,
I would recommend using Physics.Raycast rather than ScreenToWorldPoint. For something similar, you could implement it along the lines of
RaycastHit hit;
if (Physics.Raycast(Camera.main.transform.position, Camera.main.transform.TransformDirection(Vector3.forward), out hit, 100000.0f))
The hit position can be retrieved with hit.transform.
Hi @agallegos ,
thanks for the follow up. In my case, say I have an object at longitude, latitude, elevation.
After converting to Unity coordinates and raycasting from this object to the terrain, I found that it didn’t return the height of the terrain itself, but a much larger value. Actually I’m not sure what the raycast hit as it just went through the CesiumWorldTerrain.
My expected hit.transform will be a point on the terrain, and the distance will be equal to elevation.
On the Cesium3DTileset script I have the “Create physics meshes” option enabled.
Hi, was anyone able to get a solution for this yet, i tried it recently and the problem for raycasting seems to persist, any help on this would be appreciated, thanks.
Hi @Tejas_Kohli, welcome to the community!
We’re not aware of any problems with raycasting in Cesium for Unity, but it is very sensitive to passing in the right ray origin and direction. And the output will always be a position in Unity world coordinates, which are not directly relatable to longitude / latitude / height. If you’re having trouble, it might help to see your code.
