Given a Cartesian3 point, how to rotate the camera around the X axis of the point?
I need to rotate the camera from up-down to parallel to the ground, keeping the same “target”
camera.rotate(Cartesian3, angle) seem to rotate the camera only around the Z axis of the Cartesian3 point.
var myTarget = new Cesium.Cartesian3.fromDegrees(longitude, latitude);
camera.rotate(myTarget , angle);
I need to rotate the camera from top-down view to parallel to the ground keeping the same “camera target”
1.60
