A bit confused on camera rotation...
Hello, I’m new to Cesium and I’m trying ro “simply” rotate the camera around the center of the window with buttons (what you can do with CTRL+mouse click, and the basic function of every 3d map).
I can’t find any tutorial so I’ve deeped in the documentation.
I think that I should trace a ray from the camera to the center of the window, get the intersection point with the 3d terrain as Cartesian3 (the intersection point could be on a mountain, not only on flat terrain),
and use camera.lookAt(target, offset) with the intersection point as target, and the new heading/pitch of the camera.
But I’m really confused because:
  1. var ray = viewer.camera.getPickRay(windowCoordinates)
It require windowCoordinates. How can I get the center of the window?
  1. camera.lookAt(target, offset)
It require HeadingPitchRange.
How can I get the Range?
  1. I’m not sure that camera.lookAt is the right method to just modify pitch and heading and keep the same target.
Any help would be much appreciated
Thank-you
// find intersection of ray through a pixel and the globe
var windowCoordinates = new Cesium.Cartesian2(300, 300);
var ray = viewer.camera.getPickRay(windowCoordinates);
var intersection = Cesium.IntersectionTests.rayEllipsoid(ray, ellipsoid);
var point = Cesium.Ray.getPoint(ray, intersection.start);
I need to rotate the camera around the center point in the window of the terrain (what you can actually do clic with CTRL+mouse click on the map)
1.60
finally…
it doesn’t work.
with this code the camera should stay in place (no movement, no different heading / pitch / range, but the 1st click change the heading, and every time I click the button the camera move a little…
Moreover with lookAt I can’t pan the map anymore with mouse…
("#turnLeft").mousedown(function () { (this).css(‘opacity’, ‘1’);
/// get the size of the window
var elmnt = document.getElementById("map");
console.log(elmnt.offsetHeight);
console.log(elmnt.offsetWidth);
// find intersection of ray from camera to the center of the window
var ellipsoid = viewer.scene.mapProjection.ellipsoid;
var windowCoordinates = new Cesium.Cartesian2(elmnt.offsetHeight/2, elmnt.offsetWidth/2);
var intersectionPoint = Cesium.Ray.getPoint(ray, intersection.start);
/// get the range
var range = Cesium.Cartesian3.distance(camera.positionWC, intersectionPoint);
/// rotate the camera -- DOES NOT WORK
var heading = camera.heading;
var pitch = camera.pitch
viewer.camera.lookAt(intersectionPoint, new Cesium.HeadingPitchRange(heading, pitch, range));
Finally I did it.
For everybody that is struggling like me, here the code
$("#turnLeft").mousedown(function () {
$(this).css(‘opacity’, ‘1’);
if (timer != null) {
clearInterval(timer);
timer = null;
return false;
var elmnt = document.getElementById(“map”);
var windowCoordinates = new Cesium.Cartesian2(elmnt.offsetHeight / 2, elmnt.offsetWidth / 2);
timer = setInterval(function () {
camera.rotate(intersectionPoint, 0.005);
}, 10);
return false;
$("#turnLeft").mouseup(function () {
$(this).css(‘opacity’, ‘0.7’);
timer = null;
return false;
$("#turnLeft").mouseleave(function () {
timer = null;
return false;
Inserisci qui il codice…
