I recently changed my initial view of my map from a top-down birdseye view to a view from an angle.
I went from this code:
var camera = $scope.czm.scene.camera;
// var lat = 40.03883;
// var lon = -75.59777;
var lat = 38.915647;
var lon = -77.069754; // set back to -79.0698
var epsilon = 0.000400;
var west = parseFloat(lon) - epsilon;
var north = parseFloat(lat) + epsilon;
var east = parseFloat(lon) + epsilon;
var south = parseFloat(lat) - epsilon;
var scene = $scope.czm.scene;
var ellipsoid = Cesium.Ellipsoid.WGS84;
var extent = new Cesium.Rectangle.fromDegrees(west, south, east, north);
camera.viewRectangle(extent, ellipsoid);
to this code using camera.lookat to achieve the angled initial view:
var center = Cesium.Cartesian3.fromDegrees(lon, lat);
var transform = Cesium.Transforms.eastNorthUpToFixedFrame(center);
Cesium.Matrix4.clone(transform, camera.transform);
camera.constrainedAxis = Cesium.Cartesian3.UNIT_Z;
camera.lookAt(
new Cesium.Cartesian3(-100.0, -150.0, 150.0),
Cesium.Cartesian3.ZERO,
Cesium.Cartesian3.UNIT_Z);
var position = ellipsoid.cartographicToCartesian(
new Cesium.Cartographic(Cesium.Math.toRadians(lon), Cesium.Math.toRadians(lat), 0));
var screenPosition = Cesium.SceneTransforms.wgs84ToWindowCoordinates(scene, position);
The problem is that now I can no longer pan to the side using the touchpad/mouse commands that worked in the rectangular view. I think the constrained axis has changed the way my code sees the view and now when I try to pan over it turns the view on its axis. How can I initialize my map at an angle and also maintain the base camera controls for panning and angle changes (ex: holding shown command and using my touch pad will bring my camera closer to the ground).
