I am a bit confused on how to implement the callback property for my project. I want to use it to change the positions of a wall that surrounds an aircraft. I wrote the callback function so that I could adjust the position using only global variables, some of which call on other files in the project.
updateWallValues() {
var target = this.dtif.getTargetByTrafficId(this.selectedTarget);
if (target) {
var tmpLong = target.longitude;
var tmpLat = target.latitude;
var radius = this.getThresholdRangeValue;
var array: Array<number> = [];
for (var i = 0; i <= 360; i++) {
var rad = Cesium.Math.toRadians(i);
array.push(((radius/60) * Math.sin(rad)) + tmpLong);
array.push(((radius/60) * Math.cos(rad)) + tmpLat);
this.wallValues = Cesium.Cartesian3.fromDegreesArray(array);
return this.wallValues;
I input this as the positions for my wall in my callback function:
this.ThresholdOuterWall = this.viewer.entities.add({
wall: {
material: this.thresholdWallMaterial,
positions: new Cesium.CallbackProperty(this.updateWallValues, false),
minimumHeights: this.wallHeights(tmpAlti - 1000),
maximumHeights: this.wallHeights(tmpAlti + 1000),
And I update the wall with:
this.thresholdWall.wall.positions.getValue();
The error that I am getting is that “this.dtif” in one of the first lines here appears to be undefined, and therefore it can’t get the info for the “getTargetByTrafficId()” function. Can callback properties not take in global values like this? Is there something I’m doing wrong in this implementation? The function seemed to work perfectly before I implemented the Callback property (aside from flickering whenever the wall moved).
