Currently, I need to create lots of polygons and set the default “show” to false. When certain conditions met, the “show” could change to true. I understand how to use Callback property to set dynamic positions, but I am not sure if it works for bool. I don’t know if there other way to achieve this. Thanks for helping me.
var tf = new Cesium.CallbackProperty(function(){
if (value>10)
return true;
else
return false;
}, false);
let entity_example=new Cesium.Entity();
entity_example.polygon={
hierarchy: new Cesium.PolygonHierarchy(poss),
material: Cesium.Color.RED.withAlpha(0.5),
heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
show: tf
I need to control entity visibility dynamically after I create the entity.
Windows, Chrome
