I wonder if it is easy to set the 'base' color for the globe in Cesium.
I have a tile set that uses transpartent PNGs that assumes a white
background color, but the default is dark blue.
Is there a simple way to change this?
best regards,
Akos
best regards,
Akos
If you’re building Cesium yourself, you can change the color on line 106 of Source/Shaders/CentralBodyFS.glsl. If you’re using our pre-built distribution, there’s no built-in way to do it. It wouldn’t be hard to add, and I’d welcome a pull request that does it. As a workaround, you could add a layer underneath your actual layer that is a SingleTileImageryProvider with global extent, where the single tile is just a single pixel of your desired color.
Kevin
Kevin,
If you're building Cesium yourself, you can change the color on line
106 of Source/Shaders/CentralBodyFS.glsl. If you're using our
pre-built distribution, there's no built-in way to do it. It wouldn't
be hard to add, and I'd welcome a pull request that does it. As a
thanks, at the end I went with the single color SingleTile image provider.
Akos
I opened an issue on GitHub for this issue so we don’t forget about it:
