globe.pick returning undefined
I'm trying to use globe.pick to find a point directly below another point, but while IntersectionTests.rayEllipsoid does find an intersection, globe.pick is returning undefined. To test this, I decided to place a "satellite" directly above Kansas and see if it worked; it did not.
let viewer = new Cesium.Viewer('cesiumContainer');
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({url: '//assets.agi.com/stk-terrain/world'});
// The Earth
let globe = viewer.scene.globe;
let ellipsoid = globe.ellipsoid;
// Place "satellite"
let scratch = new Cesium.Cartesian3();
let kansas = Cesium.Cartesian3.fromDegrees(-101.2921054, 39.4166685);
let aboveKansas = Cesium.Cartesian3.multiplyByScalar(kansas, 1.5, scratch);
viewer.entities.add({
    position: aboveKansas,
    point: {pixelSize: 10, color: Cesium.Color.YELLOW}
let satellite = viewer.entities.getById("satellite");
let satPos = satellite.position.getValue(viewer.clock.currentTime);
// Place ray on "satellite" pointing down
let ray = new Cesium.Ray();
ray.origin = satPos;
ray.direction = Cesium.Cartesian3.negate(satPos, scratch);
// Intersection with ellipsoid
let ellipsoidIntersect = Cesium.IntersectionTests.rayEllipsoid(ray, ellipsoid);
if ((ellipsoidIntersect !== undefined) && (ellipsoidIntersect !== null)) {
    // rayEllipsoid returns an interval, where on the ray is the interval?
    let intersectPosition = Cesium.Ray.getPoint(ray, ellipsoidIntersect.start);
    console.log("ellipsoidIntersectPosition");
    console.log(intersectPosition);
} else if (ellipsoidIntersect === undefined) {
    console.log("ellipsoidIntersect undefined")
} else if (ellipsoidIntersect === null) {
    console.log("ellipsoidIntersect null")
// Intersection with terrain
let terrainIntersect = viewer.scene.globe.pick(ray, globe);
if ((terrainIntersect !== undefined) && (terrainIntersect !== null)) {
    // globe.pick returns a Cartesian3, so it's fine as it is
    console.log("terrainIntersectPosition");
    console.log(terrainIntersect);
} else if (terrainIntersect === undefined) {
    console.log("terrainIntersect undefined")
} else if (terrainIntersect === null) {
    console.log("terrainIntersect null")
The console output from this is:
a {x: -966148.3627938608, y: -4838569.813304188, z: 4028160.31341576}
I'm trying to figure out how to properly determine a ray's intersection point with terrain.
Cesium 1.41.0
Windows 10 and Chrome 64.0.3282.186
or
CentOS7 and Firefox 52.2.0
Thanks for pointing this out! I believe this may be a regression after #6115 and has to do with the order of when the globe tiles load and the pick is performed. I’ve opened #6312 to track.
In the meantime, I do get values returned (albeit inconsistently) when performing Globe.pick in a listener function subscribed to Globe.tileLoadProgressEvent, and checking Globe.tilesLoaded.
Gabby
Thanks, I look forward to the resolution.
Re-raising this as I have recently come across this and it has broken one of our workflows.
Does anyone have a workaround for this that they can share?
Reproduce steps:
  • Load Sandcastle example
  • Transform map in 2D
  • Mouse over United states
  • Identify the undefined in the terminal response
Thanks all
cheers
Hi @rileyhowley,
This actually appears to be a new issue you’re encountering - a regression due to this PR (mea culpa!). I believe I know where the issue stems from, but I’m still investigating. I’ll open an issue and follow up here once I have more information, and we’ll see if it’s possible to fix in the next release.
Matt
Appreciate it!
Issue here. I feel like I’m just shy of understanding what’s going wrong, but will pick back up tomorrow.
Still working on it, progress in issue. One thing I’ll say (for you or for others with the same issue) - if you only need an ellipsoid height and not a terrain height, you can use Camera.pickEllipsoid (which will also be much more performant).
