I’ve successfully converted a frame animated mesh into a GLTF file. Frames are :
The frames are
idle = 0 to 10
walk = 17 to 41
etc.
I’ve tried model.activeAnimations.addAll with
model.readyToRender.addEventListener( function( model) {
var startTime = Cesium.JulianDate.now();
droneModel.activeAnimations.addAll({
“speedup” : 10,
“loop” : Cesium.ModelAnimationLoop.REPEAT,
“startTime” : startTime,
“stopTime” : Cesium.JulianDate.addSeconds(startTime, 50.0, new Cesium.JulianDate()),
to try to go trough the animations but it’s not working. Any idea?
Dom
patrick
November 27, 2014, 1:51pm
2
Hi Dom,
Can you share the original COLLADA and converted glTF models?
Have you tried the example code in the 3D model Sandcastle example ?
Patrick
Hi Patrick,
I used this model found on http://www.turbosquid.com/FullPreview/Index.cfm?ID=543278&stgURLFragment=3d-models/free-fat-terrorist-3d-model/ , I attached both DAE and GLTF files with texture.
I converted from DAE to glTF using the cesium tool : http://cesiumjs.org/convertmodel.html
I supposed the difference with cesium sample is that the default animation is still; and I need to jump to futher frames. The time - frame relation is unclear to me…
best regards
Dom
animatedModel.zip (1.52 MB)
patrick
November 27, 2014, 6:14pm
4
Hi Dom,
I don’t see a library_animations in the original .dae so I don’t think the model includes animations.
As for controlling model animations using the Cesium API, check out model.activeAnimations.add .
Patrick
