I wanted to render gltf file which would contain more than one building in specefic area ,however i faced a position and orientation problem , because as stated in Cesium documentation i should state each time a position manually at cesium side for each building or gltf model . could we save the position for each building inside the gltf file instead of stating it manually?
I have read an approach done with cesium RTC json file, where it specify a center point for each gltf file , could this solve the problem?
however , i tried to render the sample inside the Cesium package which called : Box-RTC ,but it did not render for em wehn i tried to render it as normal gltf model .i would really appreciate any help regarding this issue .
Thanks
