Hello, so I want to display information on entities in my entity pool. I was thinking of using the description property. From the sandbox examples, it seems that clicking on an entity should trigger a showing of the entity’s name and description. My entities don’t display either when clicked on.
var temp = {
position : Cesium.Cartesian3.fromDegrees(lon, lat),
show: true,
billboard : {
image : img_ent,
color : color_ent,
show : true,
width : width_ent,
height : height_ent
label : {
text : ren_name,
font : ‘10pt monospace’,
fillColor: color_text,
style : Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth : 2,
verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
pixelOffset : new Cesium.Cartesian2(0, -9)
temp.name = ‘ren_guid’
temp.description = “hi this is a test!”
return temp
This temp value is returned to a variable which is then added to a collection of entities.
I do currently have a clickhandler for each entity. Essentially, the entity is clicked which raises a selected flag which then triggers actions to draw a selected icon over the selected entity in the cesium viewer.
I would like to have the entity configured such that when I read in specific data on said entity, the data corresponding to the entity will display directly on the cesium viewer or clicking and showing a box that displays the data works fine as well.
I’m using Cesium 1.15 on linux. My browser is Chrome.
