Any help is greatly appreciated~.
I have some billboard images which has multiple shapes associated with it, update rate’s probably about 300samples per 500ms;
I tried to implement the shapes with entities, but the shapes gets visualized later than the image per update if i do not use the CallbackProperty
This ‘lag’ looks confusing as I need to update the positions every 500ms and also produces this " Invalid array buffer length" error after a while.
Using the CallbackProperty on the position property didnt work too well either as the shapes doesn’t get updated at all for my desired update rate.
I tried implementing the shapes with primitives as well. While the shapes and image now updates together, it introduces lag time (probably due to the recreation of primitives).
The viewer becomes unusable on a 500ms update rate as the sample size increases as well.
below’s my code on sandcastle with the entities, feel free to comment~
var viewer = new Cesium.Viewer(‘cesiumContainer’, {sceneMode:Cesium.SceneMode.COLUMBUS_VIEW, timeline : false, animation : false});
var pinBuilder = new Cesium.PinBuilder();
var SAMPLE_SIZE= 300;
var UPDATE_RATE = 500;
var WITH_GRAPHIC = true;
var i =0, areapins=;
var area2 = ;
var ellipseOptions1 = {
semiMajorAxis : 100000,
semiMinorAxis : 100000
var ellipseOptions2 = {
material:Cesium.Color.RED.withAlpha(0.8),
semiMajorAxis : 200000,
semiMinorAxis : 200000,
var callback = function(){
return this.callbackPosition;
Cesium.when(Cesium.GroundPrimitive.initializeTerrainHeights(),function(){
for(;i<SAMPLE_SIZE; i++){
var lat = ( (0.5 - Math.random())*90).toFixed(4);
var lon = ( (0.5 - Math.random())*180).toFixed(4);
var entityOptions = {
name : 'Blank blue pin',
callbackPosition : Cesium.Cartesian3.fromDegrees(lon, lat),
billboard : {
image : pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 28).toDataURL(),
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
var entityOptions2;
if(WITH_GRAPHIC){
entityOptions.ellipse = ellipseOptions1;
entityOptions2 = {};
entityOptions2.callbackPosition = Cesium.Cartesian3.fromDegrees(lon, lat);
entityOptions2.ellipse = ellipseOptions2;
var entityInstance1 = viewer.entities.add(entityOptions);
entityInstance1.position = new Cesium.CallbackProperty(callback.bind(entityInstance1), true);
areapins.push(entityInstance1);
if(WITH_GRAPHIC){
var entityInstance2 = viewer.entities.add(entityOptions2);
entityInstance2.position = new Cesium.CallbackProperty(callback.bind(entityInstance2), true);
area2.push(entityInstance2);
var running = false;
var randomUpdate = function(){
//viewer.entities.suspendEvents();
var i2 =0, counter2= areapins.length;
for(;i2<counter2; i2++){
//areapins[i2].position.setCallback(callback.bind(areapins[i2]), false);
areapins[i2].callbackPosition = Cesium.Cartesian3.fromDegrees(lon, lat);
areapins[i2].position.setCallback(callback.bind(areapins[i2]), true);
if(WITH_GRAPHIC){
//area2[i2].position.setCallback(callback.bind(area2[i2]), false);
area2[i2].callbackPosition = Cesium.Cartesian3.fromDegrees(lon, lat);
area2[i2].position.setCallback(callback.bind(area2[i2]), true);
//viewer.entities.resumeEvents();
Sandcastle.addToolbarButton(‘Toggle Interval Updates’, function(){
running = !running;
Sandcastle.addToolbarButton(‘Update Positions’, function(){
randomUpdate();
setInterval(function(){
if(running){
randomUpdate();
}, UPDATE_RATE);
