I’m using CallbackProperty to update the opacity and the width of some polylines on the basis of camera range.
I’m quite happy about the result, but the continuos width update is very expensive for the cpu (the material color update doesn’t seem to be too expensive)
I’m wondering how to swap from a constant value to a returned function value with CallbackProperty.
I’ve tried to change “isConstant” from false to true, but it doesn’t seem to change.
P.S. DistanceDisplayCondition doesnt seem to work on mobile with polylines, from some test I did time ago
map.onReady.push(function () {
update();
map.camera.changed.addEventListener(() => {
update();
function update() {
let r = Maf.clamp(map.range, minRange, maxRange);
globalOpacity = Maf.inverseLerp(maxRange, minRange, r);
globalWidth = Maf.inverseLerp(maxRange * 2, minRange, r);
export function drawPolyline(positions, category, collection = null) {
let properties = getPropertiesFromCategory(category);
let entity = map.viewer.entities.add({
opacity: properties.opacity, /// change this value to set the opacity individually
color: properties.color,
outlineColor: properties.outlineColor,
width: properties.width,
category: category,
polyline: {
positions: positions,
clampToGround: properties.clampToGround,
// width: 5,
width: new Cesium.CallbackProperty(function () {
return entity.width * globalWidth;
}, false),
material: new Cesium.PolylineOutlineMaterialProperty({
color: new Cesium.CallbackProperty(function () {
return new Cesium.Color(entity.color.x, entity.color.y, entity.color.z, entity.opacity * globalOpacity)
outlineWidth: properties.outlineWidth,
outlineColor: new Cesium.CallbackProperty(function () {
return new Cesium.Color(entity.outlineColor.x, entity.outlineColor.y, entity.outlineColor.z, entity.opacity * globalOpacity)
show: properties.show,
if (collection) collection.push(entity);
return entity;
1.66
