When I add panoramic scenes to my Cesium app,the following error occured.
error:
An error occurred while rendering. Rendering has stopped. Cesium.js:537
undefined
TypeError: Right-hand side of 'instanceof' is not an object
at Array.<anonymous> (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:478:30868)
at F.update (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:479:3896)
at E.update (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:520:8802)
at f.update (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:524:11149)
at rt (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:530:27321)
at ht (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:531:1310)
at pt (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:531:1507)
at xe.render (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:531:9355)
at A.render (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:537:18269)
at t (http://localhost:63342/WebApp/ThirdParty/Cesium/Cesium.js:537:11719)
code1:
var clickHandler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
clickHandler.setInputAction(function (movement) {
var pickedObject = scene.pick(movement.position);
if (Cesium.defined(pickedObject)) {
var type = pickedObject.id._name.slice(0, 3);
var number = pickedObject.id._name.slice(3, 4);
if (type == 'panoramicPoint') {
$('#panoramaMode-div').animate({height: 'toggle'});
// *1 create the panorama player with the div container
var pano=new pano2vrPlayer("panoramaMode-div");
// *2 add the skin object
var skin=new pano2vrSkin(pano);
// *3 load the configuration
pano.readConfigUrlAsync("Source/pano/pano.xml");
The code's function is show the panoramic scene when I click entitis that named after 'panoramicPoint'.
The *1,*2 and *3 is the code that using to show panoramic scene in div.
When the program runs to *3 row, the error occurs.
code2:
<script type="text/javascript" src="Source/pano/pano2vr_player.js"></script>
<script type="text/javascript" src="Source/pano/skin.js"></script>
The code writed in Index.html to support showing panoramic scenes.
I want to achieve that pop up a div when I click an entity,and show panoramic scenes in the div. But when I add codes that load panoramic scenes,the error occurs.I have no ideas about the error.Is there a conflict between the CesiumJs and pano2vr_player.js?
Cesium version:1.47
browser:Chrome
