I’m just trying the simple Getting Started guide but instead of getting the Cesium instance through the global scope of the injected js file in the public/index.html I want to get the same object trough the cesium npm package
So, I’,m trying this:
import { Cesium } from ‘cesium’;
// or even this without destructuring
import Cesium from ‘cesium’;
and I’m getting the same error on both cases:
Attempted import error: ‘Cesium’ is not exported from ‘cesium’
Otherwise, how can I get the same result that this does with the actual objects that cesium npm packages provides me
Cesium.Ion.defaultAccessToken = config.settings.map.cesiumIonKey;
this.CesiumViewer = new Cesium.Viewer(‘cesiumContainer’, Object.assign({}, CESIUM_OPTIONS, {
…this.props.options
I need this because I’m trying to embed the Cesium map on a ReactJS component like this:
class CtrlCesiumMap extends PureComponent {
componentDidMount() {
…this.props.options
render() {
const { classes, id } = this.props;
return (
Furthermore, the code above totally works only if I add this to the public/index.html
Cesium npm package version: 1.63.1
OS: Windows 10
Browser: Google Chrome 78.0.3904.108
