A concise explanation of the problem you’re experiencing.
The problem I’m experiencing is that when I convert XY values to lat/long values, the returned values are massively incorrect.
I’ve tried using the code from the link below to do the conversion, which resulted in large discrepancies from where they should be. I’ve also tried using the built in Cesium functions in the GeographicTilingScheme class, which also returned incorrect values. I thought it might be because the default number of root tiles in each direction was incorrect, since the default for numberOfLevelZeroTilesX is 2 and my tileset only has 1, so I changed that and still received incorrect values.
https://wiki.openstreetmap.org/wiki/Slippy_map_tilenames
I’ve attached the layer.json file with the XY values I’m trying to use.
An example of the Python code I tried:
num2deg(57687, 10821, 15)
(52.01869808104434, 453.768310546875)
Context. Why do you need to do this? We might know a better way to accomplish your goal.
I’m trying to find the rectangle of a certain zoom level in Cesium so that I can automatically zoom to the location of the terrain
layer.json (1.83 KB)
