The polygons that I draw are covered by 3d objects as shown in the picture. How do I make the polygons appear on the floor of the models.
if this problem was with css I would use "z-index". Is there any solution in Cesium like z-index?
In that screenshot are you using ground primitives? Regular polygon primitives should not shade the 3d objects that are above them.
so is there any solution for this case?
this means; Do I not use the polygons and the tiles at the same time?
polygons created by:
var polygon = {
polygon: {
hierarchy: Cesium.Cartesian3.fromDegreesArray(coords),
material: Cesium.Color.fromCssColorString('#fff000').withAlpha(0.09),
viewer.entities.add(polygon);
tilesets created by:
tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url: '/sss',
maximumScreenSpaceError: 2,
maximumNumberOfLoadedTiles: 1000
Thanks for the sample code, I think this is a bug on our end. I opened an issue here: https://github.com/AnalyticalGraphicsInc/cesium/issues/6195.
I have changed classification type as terrain. But still doesnt work well.
viewer.scene.primitives.add(new Cesium.GroundPrimitive({
classificationType: Cesium.ClassificationType.TERRAIN
This code works for me for covering just the terrain:
Cesium.CesiumIon.create3DTileset(1458, { accessToken: ‘eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiIxYmJiNTAxOC1lOTg5LTQzN2EtODg1OC0zMWJjM2IxNGNlYmMiLCJpZCI6NDQsImFzc2V0cyI6WzE0NThdLCJpYXQiOjE0OTkyNjM4MjB9.1WKijRa-ILkmG6utrhDWX6rDgasjD7dZv-G5ZyCmkKg’ })
.then(function(tileset) {
viewer.zoomTo(tileset);
var cartographics = [new Cesium.Cartographic(-1.3194369277314022, 0.6988062530900625),
new Cesium.Cartographic(-1.3193955980204217, 0.6988091578771254),
new Cesium.Cartographic(-1.3193931220959367, 0.698743632490865),
new Cesium.Cartographic(-1.3194358224045408, 0.6987471965556998)];
var rectangle = Cesium.Rectangle.fromCartographicArray(cartographics);
var rectanglePrimitive = viewer.scene.primitives.add(new Cesium.GroundPrimitive({
geometryInstances : new Cesium.GeometryInstance({
geometry : new Cesium.RectangleGeometry({
rectangle : rectangle
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(new Cesium.Color(1.0, 0.0, 0.0, 0.5))
classificationType : Cesium.ClassificationType.TERRAIN
Thank you for answer.
So can/how i use it with lat/long?
A Cartographic is a data type that encapsulates lat, long, and optionally height.
Thank you for your help.
geometryInstances: new Cesium.GeometryInstance({
geometry: new Cesium.PolygonGeometry({
polygonHierarchy: new Cesium.PolygonHierarchy(
Cesium.Cartesian3.fromDegreesArray(-1.3194369277314022, 0.6988062530900625, -1.3193955980204217, 0.6988091578771254, -1.3193931220959367, 0.698743632490865, -1.3194358224045408, 0.6987471965556998)
attributes: {
Thanks for reporting this issue! This has been fixed and will be included in the Cesium 1.43 release available tomorrow.
Hannah
