I'm having problem with picking objects in 3D tiles which overlap some ground primitive.
In older cesium version (not sure about version since I built it from source, I think it was around 1.35) the ground primitive was displayed under 3D tiles and clicking object worked properly. I've recently updated cesium (commit '2b6afbfab26396371a557c1711ab00478399d6fd') and now it shows ground primitive strapped over 3D tiles and clicking parts covered with ground primitive returns the ground primitive (or undefined if enablePickFeatures is set to false) - http://imgur.com/a/8aqjS
I've tried adding the ground primitive to the PrimitiveCollection before or after adding 3D tileset (also lowerToBottom) but the result is always the same.
You can see it here - https://cesiumjs.org/Cesium/Apps/Sandcastle/?src=Hello%20World.html&label=Showcases&gist=c7cc5f82cfbb799cdab98bc608d2fe2e
The red circle covers buildings and clicking it returns the ground primitive first.
Is there a way to display ground primitve below 3D tileset so that it doesn't change color of covered objects from 3D tiles? I could't find anything in changelogs and it kinda broke my app since clicking on 3d tiles covered in ground primitve returns wrong object.
