hello,
I need little help here.
I’m trying to handle camera using keyboard.
I’ve seen the sandcastle example available on https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Camera%20Tutorial.html
What I want to do is:
When I press the UP/DOWN arrow it should move along the terrain surface in the direction the camera is facing in the same height.
And if I press Shift key + UP/DOWN the globe should rotate in the same way.
I’m using Cesium 1.50.
Thank you.
