hi,
Can anyone advice how to achieve this type of label ?
The total label locations is about 40-50 max.
Also can it render based on a specific offset from the terrain level.
Looked on czml in sandcastle. not sure it’s the correct approach.
TIA.
hi,
TIA.
You’ll most likely need to offset the label by a pixel amount, which you can do by specifying the pixelOffset. For example, here’s a label offset from a point:
viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(-75.1641667, 39.9522222),
label : {
text : ‘Philadelphia’,
font : ‘16pt Helvetica’,
pixelOffset: new Cesium.Cartesian2(0, -16)
point: {
pixelSize: 5
You can style each label entity and add wither a point and a polyline, or a billboard (image) which looks like the pin.
Here’s an example using Cesium’s pin builder.
Gabby
Thanks Gabby. I give it a try.
