How to add a listener to the pause button of the animation widget?
I need a way to know when the pause button was clicked. Any ideas?
-Thanks
You can observe the ClockViewModel.shouldAnimate property to detect when the clock is paused, for example:
Cesium.knockout.getObservable(viewer.animation.viewModel.clockViewModel, ‘shouldAnimate’).subscribe(function(value) {
console.log(value);
This will print false when the clock is paused.
This is a fantastic solution! Thanks.
Scott,
Your solution worked very well until I realized that I only want a listener for an actual "on click" event on the pause and play buttons. (Rather than listening for when the shouldAnimate variable changes.)
The problem is I manually change this variable in different places in my code and it's triggering my listener even when I haven't actually clicked on the pause/play buttons.
I want it to behave differently in different cases. I want to be able to know when the pause/play buttons have been clicked, without relying on what the status of the shouldAnimate variable is.
Do you know of a way to do that?
This helped me also! Thanks for your short but nice code! Now I can disable my camera flight from the pause button.
/// Function to pause the billboards flight with the animation pause button.
function animationButtonStatus() {
Cesium.knockout.getObservable(viewer.animation.viewModel.clockViewModel, 'shouldAnimate').subscribe(function (value) {
    flyBillboards = value;
/// default fuction to fly to a location
/// refactor this part!
/// information about the height of the location:
/// http://stackoverflow.com/questions/28291013/get-ground-altitude-cesiumjs
/// https://groups.google.com/forum/#!msg/cesium-dev/08DYCm0z5sM/yWgltqPkDQAJ
function flyTo(id, point_A, point_B, zoomin) {
try {
animationButtonStatus();
if (flyBillboards == true) {
var pointOfInterest = Cesium.Cartographic.fromDegrees(point_A.lon, point_A.lat, 5000, new Cesium.Cartographic());
Cesium.sampleTerrain(viewer.terrainProvider, 9, [pointOfInterest]).then(function (samples) {
var heading = Cesium.Math.toRadians(cameraManager.heading);
var pitch = Cesium.Math.toRadians(cameraManager.pitch);
viewer.scene.camera.flyTo({
destination: Cesium.Cartesian3.fromDegrees(point_A.lon, point_A.lat, samples[0].height + cameraManager.height),
duration: cameraManager.duration,
complete:
function () {
flyToComplete(id, point_A, point_B, samples[0].height, zoomin);
catch (ex) {
error(ex);
