How to add contours to cesium tiles?
By going through an example in sandcastle, I’ve isolated code to add a material to terrain that adds contours. However, when using it locally with my cesium tiles, the controus come up to the tiles and stop. Basically, everything has contour lines except the thing that needs them, the tile set. I don’t imagine anything’s wrong with Cesium, I just can’t figure the right configuration. Been working on this for a week.
On my local machine:
var Cesium = require(‘cesium/Cesium’);
require(‘cesium/Widgets/widgets.css’);
terrainProvider: Cesium.createWorldTerrain({
requestVertexNormals: true //Needed to visualize slope
var tileset = new Cesium.Cesium3DTileset({
url: “http://localhost:8080/src/data/cesium
viewer.zoomTo(tileset);
var contourColor = Cesium.Color.RED.clone();
var contourUniforms = {};
var globe = viewer.scene.globe;
var material;
material = Cesium.Material.fromType(‘ElevationContour’);
contourUniforms = material.uniforms;
contourUniforms.width = 2.0;
contourUniforms.spacing = 5.0;
contourUniforms.color = contourColor;
globe.material = material;
Working on displaying 3d products for our customers in browser with cesium. We’re a photogrammetry company.
Cesium 1.43
Ubuntu 16.04
Hi George,
I don’t think what you are trying to do is possible, at least at the moment. While terrain can use custom materials (in this case to draw the contour lines), 3D Tiles do not. You can use 3D Tiles Declarative styling (like in this tutorial), but that is more intended for styling individual features.
More customization and more analytically powerful styling is something we are certainly trying to achieve in the future, as well as more closely aligning terrain with the 3D Tiles format.
Gabby
Can the tiles be treated as terrain? Basically there would be nothing but the tiles in the model, no background terrain.
If not, I'll look into Declarative stylings in a few weeks, see what I can find out. Do you know of anyone in the cesium community who works on applying cesium to aerial mapping products who I could reach out to for advice?
The globe’s terrain and 3D Tiles are treated differently in the engine, so I don’t think currently that approach will work.
I’ve reached out for a contact that could advise you, hopefully I can get back to you soon with that!
Thanks!
Hey Gabby, did you ever find out anything more about contour lines on tile sets?
