How does Doarama draw polyline? I want to add whitish trail effect similar to what doarama does. Please see this example to get an idea what i am asking about. Can anybody help?
Hi Qandeel,
Cesium supports this, just not through the Entity layer. See here for an example of how to create a fade material for polylines: https://github.com/AnalyticalGraphicsInc/cesium/pull/4819/files
This example is part of our development examples, which are a part of Sandcastle, but only available when you build Cesium locally (not through our website).
Hope that helps,
- Rachel
Actually, it’s possible to abuse the “Stripe” material, making the white part a piece of a single stripe, to get a faded line going. For example, here I’m applying it to the ISS object from simple.czml:
Cesium.CzmlDataSource.load(’…/…/SampleData/simple.czml’).then(function(dataSource) {
viewer.camera.flyHome(0);
viewer.clock.multiplier = 1800;
var entity = dataSource.entities.getById('Satellite/ISS');
var fadedLine = new Cesium.StripeMaterialProperty({
evenColor: Cesium.Color.WHITE,
oddColor: Cesium.Color.PURPLE,
repeat: 1,
offset: 0.8,
orientation: Cesium.StripeOrientation.VERTICAL
entity.path.material = fadedLine;
entity.path.leadTime = new Cesium.ConstantProperty(0);
entity.path.trailTime = new Cesium.ConstantProperty(5400);
entity.path.width = 3;
--Ed.
Thanks for the help Rachel and Ed. I used this code:
var polyMaterial = new Cesium.Material({
fabric : {
type : ‘Stripe’,
uniforms : {
horizontal: false,
oddColor: Cesium.Color.fromCssColorString(’#FC4143’),
repeat: 1,
offset: 0.8
polyline = polylines.add({
positions: positions,
material: polyMaterial,
width: 3,
It worked like a charm.
