I am trying to add WMS layer from mapserver i.e. from localhost on Cesium Globe with the following HTML code. But I am not able to load or connect Cesium with the Mapserver and nothing is displayed on the browser. Mapserver is running successfully, there is no issue with Mapserver, I am not able to locate the error in the following code. Please tell me where I went wrong in the code.
The script, I used is -
<script id=“cesium_sandcastle_script”>
function startup(Cesium) {
“use strict”;
//Sandcastle_Begin
// Add a WMS imagery layer
var imageryLayers = viewer.imageryLayers;
imageryLayers.addImageryProvider(new Cesium.WebMapServiceImageryProvider({
url : ‘http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities’,
layers : ‘bluemarble’,
parameters : {
transparent : true,
format : ‘image/png’
// Start off looking at Australia.
viewer.camera.viewRectangle(Cesium.Rectangle.fromDegrees(114.591, -45.837, 148.970, -5.730));//Sandcastle_End
Sandcastle.finishedLoading();
if (typeof Cesium !== "undefined") {
startup(Cesium);
} else if (typeof require === "function") {
require(["Cesium"], startup);
</script>
Is there anything in the browser’s console? Any exceptions? The most likely problem is that your server does not support CORS, so browser security prevents Cesium (or any other WebGL-based library) from accessing it. http://enable-cors.org/
Kevin
I checked there is no problem with the browser's console. Actually it runs fine for WMS servers which are online, but I am having problem regarding WMS service through localhost. I am having Mapserver, it is running fine without any problem; but I am not getting the correct URL for calling WMS service from localhost Mapserver. Infact with this demo also its not working. Please indicate where I went worng with this code.
Thanks for the reply !
I think you need to provide more context/details for your problem. There are a number of things that could go wrong.
- CORS: as Kevin indicated your server may not support CORS: http://enable-cors.org
- WMS URL: in your example: http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities. This is not a localhost and I think the URL should be the base URL like: http://demo.mapserver.org/cgi-bin/wms or the localhost-equivalent.
- projection issues
Apart from the Console observe also the network traffic in the browser debugger: outgoing requests and their responses+HTTP codes.
best,
Just van den Broecke
PS Please reply to the last answer given, so the mail thread gets preserved.
