Some errors appear when I build the cesium(v1.49) following the instructions from here.
E:\yxf\yxf_code\cesium\cesium-1.49>npm install
npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at The Problem with gulp-util. A little postmortem | by Janiceilene | gulpjs | Medium
npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN deprecated nodemailer@2.7.2: All versions below 4.0.1 of Nodemailer are deprecated. See Status :: Nodemailer
npm WARN deprecated uws@9.14.0: stop using this version
npm WARN deprecated mailcomposer@4.0.1: This project is unmaintained
npm WARN deprecated socks@1.1.9: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN notice [SECURITY] lodash has the following vulnerability: 1 low. Go here for more details: https://nodesecurity.io/advisories?search=lodash&version=1.0.2 - Run npm i npm@latest -g to upgrade your npm version, and then npm audit to get more info.
npm WARN deprecated buildmail@4.0.1: This project is unmaintained
npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
npm WARN deprecated socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
npm WARN notice [SECURITY] timespan has the following vulnerability: 1 low. Go here for more details: https://nodesecurity.io/advisories?search=timespan&version=2.3.0 - Run npm i npm@latest -g to upgrade your npm version, and then npm audit to get more info.
npm WARN notice [SECURITY] minimatch has the following vulnerability: 1 high. Go here for more details: https://nodesecurity.io/advisories?search=minimatch&version=0.2.14 - Run npm i npm@latest -g to upgrade your npm version, and then npm audit to get more info.
npm WARN notice [SECURITY] minimatch has the following vulnerability: 1 high. Go here for more details: https://nodesecurity.io/advisories?search=minimatch&version=2.0.10 - Run npm i npm@latest -g to upgrade your npm version, and then npm audit to get more info.
uws@9.14.0 install E:\yxf\yxf_code\cesium\cesium-1.49\node_modules\uws
node-gyp rebuild > build_log.txt 2>&1 || exit 0
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
