I unzip cesium to a folder called Cesium. In cesium I use command shell but receive these errors
C:\Cesium>npm install
npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN deprecated lodash@1.0.2: lodash@<3.0.0 is no longer maintained. Upgrade to lodash@^4.0.0.
npm WARN deprecated graceful-fs@1.2.3: graceful-fs v3.0.0 and before will fail on node releases >= v7.0. Please update to graceful-fs@^4.0.0 as soon as possible. Use ‘npm ls graceful-fs’ to find it in the tree.
npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (GitHub - jprichardson/node-fs-extra: Node.js: extra methods for the fs object like copy(), remove(), mkdirs()) for any operations you were using wrench for. Thanks for all the usage over the years.
npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
npm WARN prefer global marked@0.3.6 should be installed with -g
electron-prebuilt@1.3.1 postinstall C:\Cesium\node_modules\electron-prebuilt
node install.js
cesium@1.24.0 C:\Cesium
±- almond@0.3.2
±- aws-sdk@2.4.10
±- jmespath@0.15.0
±- sax@1.1.5
±- xml2js@0.4.15
`-- xmlbuilder@2.6.2
`-- lodash@3.5.0
±- bluebird@3.4.1
±- compressible@2.0.8
`-- mime-db@1.23.0
±- compression@1.6.2
±- accepts@1.3.3
`-- negotiator@0.6.1
±- bytes@2.3.0
±- debug@2.2.0
`-- ms@0.7.1
±- on-headers@1.0.1
`-- vary@1.1.0
±- electron-prebuilt@1.3.1
±- electron-download@2.1.2
±- home-path@1.0.3
±- mv@2.1.1
`-- rimraf@2.4.5
`-- glob@6.0.4
±- nugget@1.6.2
±- pretty-bytes@1.0.4
±- progress-stream@1.2.0
±- speedometer@0.1.4
`-- through2@0.2.3
`-- xtend@2.1.2
`-- object-keys@0.4.0
±- single-line-log@0.4.1
`-- throttleit@0.0.2
±- path-exists@1.0.0
`-- rc@1.1.6
±- deep-extend@0.4.1
`-- ini@1.3.4
`-- extract-zip@1.5.0
±- debug@0.7.4
±- mkdirp@0.5.0
`-- minimist@0.0.8
`-- yauzl@2.4.1
`-- fd-slicer@1.0.1
`-- pend@1.2.0
±- event-stream@3.3.4
±- duplexer@0.1.1
±- from@0.1.3
±- map-stream@0.1.0
±- pause-stream@0.0.11
±- split@0.3.3
±- stream-combiner@0.0.4
`-- through@2.3.8
±- express@4.14.0
±- array-flatten@1.1.1
±- content-disposition@0.5.1
±- content-type@1.0.2
±- cookie@0.3.1
±- cookie-signature@1.0.6
±- depd@1.1.0
±- encodeurl@1.0.1
±- escape-html@1.0.3
±- etag@1.7.0
±- finalhandler@0.5.0
±- statuses@1.3.0
`-- unpipe@1.0.0
±- fresh@0.3.0
±- merge-descriptors@1.0.1
±- methods@1.1.2
±- on-finished@2.3.0
`-- ee-first@1.1.1
±- parseurl@1.3.1
±- path-to-regexp@0.1.7
±- proxy-addr@1.1.2
±- forwarded@0.1.0
`-- ipaddr.js@1.1.1
±- qs@6.2.0
±- range-parser@1.2.0
±- send@0.14.1
±- destroy@1.0.4
`-- http-errors@1.5.0
`-- setprototypeof@1.0.1
±- serve-static@1.11.1
±- type-is@1.6.13
`-- media-typer@0.3.0
`-- utils-merge@1.0.0
±- globby@6.0.0
±- array-union@1.0.2
`-- array-uniq@1.0.3
±- glob@7.0.5
±- fs.realpath@1.0.0
±- inflight@1.0.5
`-- wrappy@1.0.2
±- inherits@2.0.1
±- once@1.3.3
`-- path-is-absolute@1.0.0
±- object-assign@4.1.0
±- pify@2.3.0
`-- pinkie-promise@2.0.1
`-- pinkie@2.0.4
±- gulp@3.9.1
±- archy@1.0.0
±- chalk@1.1.3
±- ansi-styles@2.2.1
±- has-ansi@2.0.0
`-- ansi-regex@2.0.0
±- strip-ansi@3.0.1
`-- supports-color@2.0.0
±- deprecated@0.0.1
±- gulp-util@3.0.7
±- array-differ@1.0.0
±- dateformat@1.0.12
±- get-stdin@4.0.1
`-- meow@3.7.0
±- camelcase-keys@2.1.0
`-- camelcase@2.1.1
±- loud-rejection@1.6.0
±- currently-unhandled@0.4.1
`-- array-find-index@1.0.1
`-- signal-exit@3.0.0
±- map-obj@1.0.1
±- redent@1.0.0
±- indent-string@2.1.0
`-- repeating@2.0.1
`-- is-finite@1.0.1
`-- strip-indent@1.0.1
`-- trim-newlines@1.0.0
±- fancy-log@1.2.0
`-- time-stamp@1.0.1
±- gulplog@1.0.0
`-- glogg@1.0.0
±- has-gulplog@0.1.0
`-- sparkles@1.0.0
±- lodash._reescape@3.0.0
±- lodash._reevaluate@3.0.0
±- lodash._reinterpolate@3.0.0
±- lodash.template@3.6.2
±- lodash._basecopy@3.0.1
±- lodash._basetostring@3.0.1
±- lodash._basevalues@3.0.0
±- lodash._isiterateecall@3.0.9
±- lodash.escape@3.2.0
`-- lodash._root@3.0.1
±- lodash.keys@3.1.2
±- lodash._getnative@3.9.1
±- lodash.isarguments@3.1.0
`-- lodash.isarray@3.0.4
±- lodash.restparam@3.6.1
`-- lodash.templatesettings@3.1.1
±- multipipe@0.1.2
`-- duplexer2@0.0.2
±- object-assign@3.0.0
±- replace-ext@0.0.1
±- through2@2.0.1
±- readable-stream@2.0.6
`-- isarray@1.0.0
`-- xtend@4.0.1
`-- vinyl@0.5.3
±- clone@1.0.2
`-- clone-stats@0.0.1
±- interpret@1.0.1
±- liftoff@2.3.0
±- findup-sync@0.4.2
±- detect-file@0.1.0
`-- fs-exists-sync@0.1.0
±- micromatch@2.3.11
±- arr-diff@2.0.0
`-- arr-flatten@1.0.1
±- braces@1.8.5
±- expand-range@1.8.2
`-- fill-range@2.2.3
±- is-number@2.1.0
±- isobject@2.1.0
`-- isarray@1.0.0
±- randomatic@1.1.5
`-- repeat-string@1.5.4
±- preserve@0.2.0
`-- repeat-element@1.1.2
±- expand-brackets@0.1.5
`-- is-posix-bracket@0.1.1
±- extglob@0.3.2
±- filename-regex@2.0.0
±- kind-of@3.0.4
`-- is-buffer@1.1.4
±- normalize-path@2.0.1
±- object.omit@2.0.0
±- for-own@0.1.4
`-- for-in@0.1.5
`-- is-extendable@0.1.1
±- parse-glob@3.0.4
±- glob-base@0.3.0
`-- is-dotfile@1.0.2
`-- regex-cache@0.4.3
±- is-equal-shallow@0.1.3
`-- is-primitive@2.0.0
`-- resolve-dir@0.1.1
`-- global-modules@0.2.3
+-- global-prefix@0.1.4
> `-- osenv@0.1.3
`-- is-windows@0.2.0
±- fined@1.0.1
±- expand-tilde@1.2.2
±- lodash.assignwith@4.2.0
±- lodash.isarray@4.0.0
±- lodash.isempty@4.4.0
±- lodash.pick@4.4.0
`-- parse-filepath@1.0.1
±- is-absolute@0.2.5
±- is-relative@0.2.1
`-- is-unc-path@0.1.1
`-- unc-path-regex@0.1.2
`-- is-windows@0.1.1
±- map-cache@0.2.2
`-- path-root@0.1.1
`-- path-root-regex@0.1.2
±- flagged-respawn@0.3.2
±- lodash.isplainobject@4.0.6
±- lodash.isstring@4.0.1
±- lodash.mapvalues@4.6.0
±- rechoir@0.6.2
`-- resolve@1.1.7
±- minimist@1.2.0
±- orchestrator@0.3.7
±- end-of-stream@0.1.5
±- sequencify@0.0.7
`-- stream-consume@0.1.0
±- pretty-hrtime@1.0.2
±- semver@4.3.6
±- tildify@1.2.0
`-- os-homedir@1.0.1
±- v8flags@2.0.11
`-- user-home@1.1.1
`-- vinyl-fs@0.3.14
±- defaults@1.0.3
±- glob-stream@3.1.18
±- glob@4.5.3
±- glob2base@0.0.12
`-- find-index@0.1.1
±- minimatch@2.0.10
±- ordered-read-streams@0.1.0
±- through2@0.6.5
±- readable-stream@1.0.34
`-- xtend@4.0.1
`-- unique-stream@1.0.0
±- glob-watcher@0.0.6
`-- gaze@0.5.2
`-- globule@0.1.0
+-- glob@3.1.21
> +-- graceful-fs@1.2.3
> `-- inherits@1.0.2
+-- lodash@1.0.2
`-- minimatch@0.2.14
±- graceful-fs@3.0.10
`-- natives@1.0.1
±- strip-bom@1.0.0
±- first-chunk-stream@1.0.0
`-- is-utf8@0.2.1
±- through2@0.6.5
`-- xtend@4.0.1
`-- vinyl@0.4.6
`-- clone@0.2.0
±- gulp-insert@0.5.0
±- readable-stream@1.1.14
±- core-util-is@1.0.2
±- isarray@0.0.1
`-- string_decoder@0.10.31
`-- streamqueue@0.0.6
±- gulp-jshint@2.0.1
±- lodash@4.15.0
±- minimatch@2.0.10
`-- brace-expansion@1.1.6
±- balanced-match@0.4.2
`-- concat-map@0.0.1
±- rcloader@0.1.2
±- lodash@2.4.2
`-- rcfinder@0.1.9
`-- lodash.clonedeep@4.5.0
`-- through2@0.6.5
`-- xtend@4.0.1
±- gulp-rename@1.2.2
±- gulp-replace@0.5.4
±- istextorbinary@1.0.2
±- binaryextensions@1.0.1
`-- textextensions@1.0.2
±- readable-stream@2.1.5
±- buffer-shims@1.0.0
±- isarray@1.0.0
±- process-nextick-args@1.0.7
`-- util-deprecate@1.0.2
`-- replacestream@4.0.2
`-- readable-stream@2.1.5
`-- isarray@1.0.0
±- gulp-zip@3.0.2
±- concat-stream@1.5.0
`-- isarray@1.0.0
`-- typedarray@0.0.6
±- through2@0.6.5
`-- xtend@4.0.1
`-- yazl@2.4.1
`-- buffer-crc32@0.2.5
±- jasmine-core@2.4.1
±- jsdoc@3.4.0
±- async@1.4.2
±- bluebird@2.9.34
±- catharsis@0.8.8
`-- underscore-contrib@0.3.0
`-- underscore@1.6.0
±- escape-string-regexp@1.0.5
±- espree@2.2.5
±- js2xmlparser@1.0.0
±- marked@0.3.6
±- requizzle@0.2.1
±- strip-json-comments@1.0.4
±- taffydb@2.6.2
±- underscore@1.8.3
`-- wrench@1.5.9
±- jshint@2.9.2
±- cli@0.6.6
`-- glob@3.2.11
`-- minimatch@0.3.0
+-- lru-cache@2.7.3
`-- sigmund@1.0.1
±- console-browserify@1.1.0
`-- date-now@0.1.4
±- exit@0.1.2
±- htmlparser2@3.8.3
±- domelementtype@1.3.0
±- domhandler@2.3.0
±- domutils@1.5.1
`-- dom-serializer@0.1.0
±- domelementtype@1.1.3
`-- entities@1.1.1
`-- entities@1.0.0
±- lodash@3.7.0
±- minimatch@2.0.10
`-- shelljs@0.3.0
±- jshint-stylish@2.2.0
±- beeper@1.1.0
±- log-symbols@1.0.2
±- plur@2.1.2
`-- irregular-plurals@1.2.0
±- string-length@1.0.1
`-- text-table@0.2.0
±- karma@1.1.2
±- body-parser@1.15.2
±- bytes@2.4.0
±- iconv-lite@0.4.13
±- qs@6.2.0
`-- raw-body@2.1.7
`-- bytes@2.4.0
±- chokidar@1.6.0
±- anymatch@1.3.0
`-- arrify@1.0.1
±- async-each@1.0.0
±- glob-parent@2.0.0
±- is-binary-path@1.0.1
`-- binary-extensions@1.5.0
±- is-glob@2.0.1
`-- is-extglob@1.0.0
`-- readdirp@2.1.0
`-- isarray@1.0.0
`-- set-immediate-shim@1.0.1
±- colors@1.1.2
±- combine-lists@1.0.0
`-- lodash@4.15.0
±- connect@3.4.1
`-- finalhandler@0.4.1
±- core-js@2.4.1
±- di@0.0.1
±- dom-serialize@2.2.1
±- custom-event@1.0.0
±- ent@2.2.0
`-- void-elements@2.0.1
±- expand-braces@0.1.2
±- array-slice@0.2.3
±- array-unique@0.2.1
`-- braces@0.1.5
`-- expand-range@0.1.1
+-- is-number@0.1.1
`-- repeat-string@0.2.2
±- glob@7.0.5
±- graceful-fs@4.1.6
±- http-proxy@1.14.0
±- eventemitter3@1.2.0
`-- requires-port@1.0.0
±- isbinaryfile@3.0.1
±- lodash@3.10.1
±- log4js@0.6.38
`-- semver@4.3.6
±- minimatch@3.0.3
±- optimist@0.6.1
±- minimist@0.0.10
`-- wordwrap@0.0.3
±- qjobs@1.1.5
±- socket.io@1.4.7
±- engine.io@1.6.10
±- accepts@1.1.4
±- mime-types@2.0.14
`-- mime-db@1.12.0
`-- negotiator@0.4.9
±- base64id@0.1.0
±- engine.io-parser@1.2.4
±- after@0.8.1
±- arraybuffer.slice@0.0.6
±- base64-arraybuffer@0.1.2
±- blob@0.0.4
±- has-binary@0.1.6
`-- utf8@2.1.0
`-- ws@1.0.1
±- options@0.0.6
`-- ultron@1.0.2
±- has-binary@0.1.7
±- socket.io-adapter@0.4.0
`-- socket.io-parser@2.2.2
±- debug@0.7.4
`-- json3@3.2.6
±- socket.io-client@1.4.6
±- backo2@1.0.2
±- component-bind@1.0.0
±- component-emitter@1.2.0
±- engine.io-client@1.6.9
±- component-inherit@0.0.3
±- has-cors@1.1.0
±- parsejson@0.0.1
±- parseqs@0.0.2
±- xmlhttprequest-ssl@1.5.1
`-- yeast@0.1.2
±- indexof@0.0.1
±- object-component@0.0.3
±- parseuri@0.0.4
`-- better-assert@1.0.2
`-- callsite@1.0.0
`-- to-array@0.1.4
`-- socket.io-parser@2.2.6
±- benchmark@1.0.0
±- component-emitter@1.1.2
`-- json3@3.3.2
±- source-map@0.5.6
±- tmp@0.0.28
`-- os-tmpdir@1.0.1
`-- useragent@2.1.9
`-- lru-cache@2.2.4
±- karma-chrome-launcher@1.0.1
±- fs-access@1.0.0
`-- null-check@1.0.0
`-- which@1.2.10
`-- isexe@1.1.2
±- karma-detect-browsers@2.1.0
±- karma-electron-launcher@0.1.0
±- async@0.9.2
±- merge@1.2.0
`-- ncp@2.0.0
±- karma-firefox-launcher@1.0.0
±- karma-ie-launcher@1.0.0
`-- lodash@4.15.0
±- karma-jasmine@1.0.2
±- karma-requirejs@1.0.0
±- karma-safari-launcher@1.0.0
±- karma-spec-reporter@0.0.26
`-- colors@0.6.2
±- mime@1.3.4
±- mkdirp@0.5.1
`-- minimist@0.0.8
±- request@2.74.0
±- aws-sign2@0.6.0
±- aws4@1.4.1
±- bl@1.1.2
`-- readable-stream@2.0.6
`-- isarray@1.0.0
±- caseless@0.11.0
±- combined-stream@1.0.5
`-- delayed-stream@1.0.0
±- extend@3.0.0
±- forever-agent@0.6.1
±- form-data@1.0.0-rc4
`-- async@1.5.2
±- har-validator@2.0.6
±- commander@2.9.0
`-- graceful-readlink@1.0.1
`-- is-my-json-valid@2.13.1
±- generate-function@2.0.0
±- generate-object-property@1.2.0
`-- is-property@1.0.2
±- jsonpointer@2.0.0
`-- xtend@4.0.1
±- hawk@3.1.3
±- boom@2.10.1
±- cryptiles@2.0.5
±- hoek@2.16.3
`-- sntp@1.0.9
±- http-signature@1.1.1
±- assert-plus@0.2.0
±- jsprim@1.3.0
±- extsprintf@1.0.2
±- json-schema@0.2.2
`-- verror@1.3.6
`-- sshpk@1.9.2
±- asn1@0.2.3
±- assert-plus@1.0.0
±- dashdash@1.14.0
`-- assert-plus@1.0.0
±- ecc-jsbn@0.1.1
±- getpass@0.1.6
±- jodid25519@1.0.2
±- jsbn@0.1.0
`-- tweetnacl@0.13.3
±- is-typedarray@1.0.0
±- isstream@0.1.2
±- json-stringify-safe@5.0.1
±- mime-types@2.1.11
±- node-uuid@1.4.7
±- oauth-sign@0.8.2
±- qs@6.2.1
±- stringstream@0.0.5
±- tough-cookie@2.3.1
`-- tunnel-agent@0.4.3
±- requirejs@2.2.0
±- rimraf@2.5.3
`-- glob@7.0.5
±- strip-comments@0.3.2
`-- yargs@4.8.1
±- cliui@3.2.0
`-- wrap-ansi@2.0.0
±- decamelize@1.2.0
±- get-caller-file@1.0.2
±- lodash.assign@4.2.0
±- os-locale@1.4.0
`-- lcid@1.0.0
`-- invert-kv@1.0.0
±- read-pkg-up@1.0.1
±- find-up@1.1.2
`-- path-exists@2.1.0
`-- read-pkg@1.1.0
±- load-json-file@1.1.0
±- parse-json@2.2.0
`-- error-ex@1.3.0
`-- is-arrayish@0.2.1
`-- strip-bom@2.0.0
±- normalize-package-data@2.3.5
±- hosted-git-info@2.1.5
±- is-builtin-module@1.0.0
`-- builtin-modules@1.1.1
±- semver@5.3.0
`-- validate-npm-package-license@3.0.1
±- spdx-correct@1.0.2
`-- spdx-license-ids@1.2.2
`-- spdx-expression-parse@1.0.2
`-- spdx-exceptions@1.0.5
`-- path-type@1.1.0
±- require-directory@2.1.1
±- require-main-filename@1.0.1
±- set-blocking@2.0.0
±- string-width@1.0.2
±- code-point-at@1.0.0
`-- number-is-nan@1.0.0
`-- is-fullwidth-code-point@1.0.0
±- which-module@1.0.0
±- window-size@0.2.0
±- y18n@3.2.1
`-- yargs-parser@2.4.1
`-- camelcase@3.0.0
npm WARN optional Skipping failed optional dependency /chokidar/fsevents:
npm WARN notsup Not compatible with your operating system or architecture: fsevents@1.0.14
C:\Cesium>
Any help would be very helpfull
