Id’ like to fade entyies (billboards, labels, etc) on the base of their own distance from the camera, and the camera pitch.
With “CallbackProperty” I can’t pass to the function the entity position, to calculate the distance.
If I change their material properties directly obviously them flash.
Is there another way?
Thank-you
To fade
1.66
