Thank you for sharing this information with the community! I would love to learn more about how you are updating your satellite entity. Be sure to check that you are using the correct units when updating the orientation of this entity.
@11118, it looks like Entity.orientation expects an object of type Property. I suggest that you use the member Property.definitionChanged to help ensure that you are actually updating the orientation of your entity.
I do not have a lot of experience using the VelocityOrientationProperty object. You might want to investigate how exactly the quaternion is generated from this object. It’s also possible that your entity data is inconsistent, yielding an unexpected orientation.
