hello,
I'm using orientation : new Cesium.VelocityOrientationProperty(property) but the model is pointing to the north and doesn't change, do you know why?
to try my code, replace registration string on line 20 with registration of active airplane from flightradar24.com
var newLat=49.451413;
var newLong=2.111137;
var track_old=0;
var delta_track=0;
var track=0;
var res4; //latitude_value
var res5; // longitude_value
var res6;
var res7;
var res8=0;
var res9=0;
var timer=0;
var camtime=Date.now();
var datatime=0;
var datatimeold=0;
var cameraAngle = 1;
var dataAvailable=0;
var position;
var timerimmat= 0;
var registration= 'F-GRHQ';
var start=Date.now();
var stop = Cesium.JulianDate.addSeconds(start, 360, new Cesium.JulianDate());
var time = Cesium.JulianDate.addSeconds(start, 45, new Cesium.JulianDate());
var timermodel=0;
var i=0;
var vspeed=0;
var orientation;
infoBox: false, //Disable InfoBox widget
selectionIndicator: false, //Disable selection indicator
shouldAnimate: true, // Enable animations
terrainProvider: Cesium.createWorldTerrain()
//Enable lighting based on sun/moon positions
viewer.scene.globe.enableLighting = true;
//Enable depth testing so things behind the terrain disappear.
viewer.scene.globe.depthTestAgainstTerrain = true;
//Set the random number seed for consistent results.
Cesium.Math.setRandomNumberSeed(3);
flightradar();
function clocking(){
stop = Cesium.JulianDate.addHours(datatime,12,new Cesium.JulianDate());
time = datatime;
//Make sure viewer is at the desired time.
viewer.clock.startTime = start.clone();
viewer.clock.stopTime = stop.clone();
viewer.clock.currentTime = start.clone();
viewer.clock.multiplier = 1;
//Set timeline to simulation bounds
viewer.timeline.zoomTo(start, stop);
var property = new Cesium.SampledPositionProperty();
var trackproperty= new Cesium.SampledPositionProperty();
property.setInterpolationOptions({
interpolationDegree : 5,
interpolationAlgorithm : Cesium.LagrangePolynomialApproximation
trackproperty.setInterpolationOptions({
// generate buffer with flight data
function computeCirclularFlight(lon, lat, height, timedata, tracksample) {
//time = timedata;//;//timedata;
position = Cesium.Cartesian3.fromDegrees(lon, lat, height);
var heading = Cesium.Math.toRadians(tracksample);
var pitch = Cesium.Math.toRadians(0);
var roll = Cesium.Math.toRadians(0);
var hpRoll = new Cesium.HeadingPitchRoll(heading,pitch,roll);
var sampleorientation = Cesium.Transforms.headingPitchRollQuaternion(position,hpRoll);
property.addSample(time, position);
trackproperty.addSample(time, sampleorientation);
//Also create a point for each sample we generate.
viewer.entities.add({
position : position,
point : {
pixelSize : 8,
color : Cesium.Color.TRANSPARENT,
outlineColor : Cesium.Color.YELLOW,
outlineWidth : 3
return property;
//Actually create the entity
//Use our computed positions
//Automatically compute orientation based on position movement.
//orientation : new Cesium.VelocityOrientationProperty(property),
//Load the Cesium plane model to represent the entity
model : {
uri : '../../../../Apps/SampleData/models/CesiumAir/Cesium_Air.gltf',
minimumPixelSize : 64
function flightradar()
var date= Date.now();
var res;
var url = 'https://data-live.flightradar24.com/zones/fcgi/feed.js?reg=!’+registration;
var doc= new XMLHttpRequest();
doc.onreadystatechange = function(){
if(doc.readyState == XMLHttpRequest.DONE){
res=doc.responseText;//JS.data(doc.responseText);
//console.log(res);
dataAvailable=res.length
if(dataAvailable>40)
var res1=res.split("[");
var res2=res1[1];
var res3=res2.split(",");
res4=parseFloat(res3[1]); //latitude_value
res5=parseFloat(res3[2]); // longitude_value
res6=parseFloat(res3[3])-90; // track_value
res7=parseFloat(res3[4])*0.3048; // altitude_value
res8=parseFloat(res3[5]); // speed_value
res9=parseInt((parseFloat(res3[15])*0.4*100)/100); // Vspeed_value
datatime=Cesium.JulianDate.fromDate(new Date(parseInt(res3[10])*1000));// timestamp of data recorded
if(datatime!==undefined && datatime!==0 && datatimeold<parseInt(res3[10]))
start=datatime;
datatimeold=parseInt(res3[10]);
doc.open('GET', url, true);
doc.send();
viewer.clock.onTick.addEventListener(function(clock){
if(Date.now()>=timer+500)
flightradar();
if(datatime!==undefined && datatime!==0)
clocking();
computeCirclularFlight(res5,res4, res7,datatime,res6);
datatimeold=datatime;
entity.viewFrom= new Cesium.Cartesian3(30, 30, 10);
timer=Date.now();
if(Date.now()>=timermodel+10)
if(Date.now()<=timer+500)
i=i+0.01;
var propertyPosition=property.getValue(Cesium.JulianDate.addSeconds(start, i, new Cesium.JulianDate()));
if(propertyPosition!==undefined)
entity.position=propertyPosition;
entity.orientation=trackproperty.getValue(Cesium.JulianDate.addSeconds(start, i, new Cesium.JulianDate()));//new Cesium.VelocityOrientationProperty(entity.position);//
//console.log(trackproperty.getValue(Cesium.JulianDate.addSeconds(start, i, new Cesium.JulianDate())));
timermodel=Date.now();
