Hello Cesium-community,
I met a problem with velocityOrientationProperty in Cesium, please see the description as follows:
I am working on a cesium project and the goal is to display the vehicles driving according to their gpx tracks on maps. I basically modified the Cesium Workshop tutorial to my case. I have generated the CZML file where the coordinates inside are cartographicDegrees(longtitude, latitude,height). But it seems the orientation of the vehicle didn’t change as the drone in Cesium workshop when running .
var vehicle;
vehicleroute.then(function(dataSource){
vehicle = dataSource.entities.getById('Point');
vehicle.model = {
uri: './Source/SampleData/Models/CesiumMilkTruck.gltf',
minimumPixelSize : 12,
maximumScale : 1000,
silhouetteColor : Cesium.Color.WHITE,
vehicle.orientation = new Cesium.VelocityOrientationProperty(vehicle.position);
As described in 1.
Version: 1.57.
FYI, my codes are available on github: https://github.com/kathy-lee/cesium-workshop. Thanks in advance!
Kind regards,
Kathy
