Create my command code:
_mergeTexture(currViewShed){
let _this = this;
let context = this.viewer.scene.context;
if(currViewShed.drawDepthCommand){
currViewShed.drawDepthCommand.execute(context);
return;
let fs = MergeViewFieldFS;
// // rs.blending.enabled = true;
// // rs.blending.functionSourceAlpha = context._gl.ONE;
// // rs.blending.functionSourceRgb = context._gl.ONE;
// // rs.blending.functionDestinationAlpha = context._gl.ONE;
var bias = currViewShed.viewShadowMap._isPointLight ? currViewShed.viewShadowMap._pointBias : currViewShed.viewShadowMap._primitiveBias;
let uniformMap = {
czzj: function () {
return currViewShed.verticalAngle;
dis: function () {
return currViewShed.distance;
spzj: function () {
return currViewShed.horizontalAngle;
visibleColor: function () {
return currViewShed.visibleAreaColor;
disVisibleColor: function () {
return currViewShed.hiddenAreaColor;
stcshadow: function () {
return currViewShed.viewShadowMap._shadowMapTexture;
_shadowMap_matrix: function () {
return currViewShed.viewShadowMap._shadowMapMatrix;
shadowMap_lightPositionEC: function () {
return currViewShed.viewShadowMap._lightPositionEC;
shadowMap_lightDirectionEC: function () {
return currViewShed.viewShadowMap._lightDirectionEC;
shadowMap_lightUp: function () {
return currViewShed.viewShadowMap._lightCamera.up;
shadowMap_lightDir: function () {
return currViewShed.viewShadowMap._lightCamera.direction;
shadowMap_lightRight: function () {
return currViewShed.viewShadowMap._lightCamera.right;
shadowMap_texelSizeDepthBiasAndNormalShadingSmooth: function () {
var texelStepSize = new Cesium.Cartesian2();
texelStepSize.x = 1.0 / currViewShed.viewShadowMap._textureSize.x;
texelStepSize.y = 1.0 / currViewShed.viewShadowMap._textureSize.y;
return Cesium.Cartesian4.fromElements(texelStepSize.x, texelStepSize.y, bias.depthBias, bias.normalShadingSmooth, this.combinedUniforms1);
shadowMap_normalOffsetScaleDistanceMaxDistanceAndDarkness: function () {
return Cesium.Cartesian4.fromElements(bias.normalOffsetScale, currViewShed.viewShadowMap._distance, currViewShed.viewShadowMap.maximumDistance, currViewShed.viewShadowMap._darkness, this.combinedUniforms2);
depthTexture:function(){
return _this.getSceneDepthTexture(_this.viewer);
var fbo = this.mergeFBO;
var rs = new Cesium.RenderState();
var pass = Cesium.Pass.TRANSLUCENT;
currViewShed.drawDepthCommand = context.createViewportQuadCommand(fs,{
renderState:rs,
uniformMap:uniformMap,
owner:currViewShed,
framebuffer:fbo,
pass:pass
My FragmengtShader code snippet:
vec4 toEye(in vec2 uv, in float depth){
vec2 xy = vec2((uv.x * 2.0 - 1.0),(uv.y * 2.0 - 1.0));
vec4 posInCamera =czm_inverseProjection * vec4(xy, depth, 1.0);
posInCamera =posInCamera / posInCamera.w;
return posInCamera;
float getDepth(in vec4 depth){
float z_window = czm_unpackDepth(depth);
z_window = czm_reverseLogDepth(z_window);
float n_range = czm_depthRange.near;
float f_range = czm_depthRange.far;
return (2.0 * z_window - n_range - f_range) / (f_range - n_range);
float _czm_sampleShadowMap(sampler2D shadowMap, vec2 uv){
return texture2D(shadowMap, uv).r;
float _czm_shadowDepthCompare(sampler2D shadowMap, vec2 uv, float depth){
return step(depth, _czm_sampleShadowMap(shadowMap, uv));
float _czm_shadowVisibility(sampler2D shadowMap, czm_shadowParameters shadowParameters){
float depthBias = shadowParameters.depthBias;
float depth = shadowParameters.depth;
float nDotL = shadowParameters.nDotL;
float normalShadingSmooth = shadowParameters.normalShadingSmooth;
float darkness = shadowParameters.darkness;
vec2 uv = shadowParameters.texCoords;
depth -= depthBias;
vec2 texelStepSize = shadowParameters.texelStepSize;
float radius = 1.0;
float dx0 = -texelStepSize.x * radius;
float dy0 = -texelStepSize.y * radius;
float dx1 = texelStepSize.x * radius;
float dy1 = texelStepSize.y * radius;
float visibility =
_czm_shadowDepthCompare(shadowMap, uv, depth)
+_czm_shadowDepthCompare(shadowMap, uv + vec2(dx0, dy0), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(0.0, dy0), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(dx1, dy0), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(dx0, 0.0), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(dx1, 0.0), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(dx0, dy1), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(0.0, dy1), depth) +
_czm_shadowDepthCompare(shadowMap, uv + vec2(dx1, dy1), depth)
) * (1.0 / 9.0)
return visibility;
vec3 pointProjectOnPlane(in vec3 planeNormal, in vec3 planeOrigin, in vec3 point){
vec3 v01 = point -planeOrigin;
float d = dot(planeNormal, v01) ;
return (point - planeNormal * d);
float ptm(vec3 pt){
return sqrt(pt.x*pt.x + pt.y*pt.y + pt.z*pt.z);
void main()
const float PI = 3.141592653589793;
vec4 currD = texture2D(depthTexture, v_textureCoordinates);
vec4 color = vec4(0.0,0.0,1.0,1.0);
// vec4 stcc = texture2D(stcshadow, v_textureCoordinates);
// gl_FragColor = stcc;
// return;
if(gl_FragColor.g>0.3){
gl_FragColor = vec4(0.0,1.0,0.0,1.0);
return;
if(currD.r>=1.0){
gl_FragColor = vec4(1.0,1.0,0.0,1.0);
return;
float depth = getDepth(currD);
vec4 positionEC = toEye(v_textureCoordinates, depth);
vec3 normalEC = vec3(1.0);
//坐标与视点位置距离,大于最大距离则舍弃阴影效果
vec4 lw = czm_inverseView* vec4(shadowMap_lightPositionEC.xyz, 1.0);
vec4 vw = czm_inverseView* vec4(positionEC.xyz, 1.0);
if(distance(lw.xyz,vw.xyz)>dis){
gl_FragColor = vec4(1.0,1.0,1.0,1.0);
return;
Why is distance (lw. xyz, vw. xyz)>dis always true?
