How to get the position of a node in the model in space
I have drawn a model on the earth, and the nodes on the model will rotate. How can I get the spatial position of this node of the model
Hi @11118
You can use the ModelNode.matrix property to get the model-space transform of the node, then multiply that by the Model.modelMatrix to get the current world-space transform. You can then extract the world-space Cartesian3 position using Matrix4.getTranslation(). Here is a Sandcastle for demonstration.
Hope this helps,
Sam.
It seems to be some error in the calculation.It is test result
The problem has been solved, thanks!
How did you solve the problem of coordinate offset
