How to hide a single geometry instance?
Hi all,
I need to hide a single geometry instance after batching. Please see the code example below. Is it possible to do this? Thanks in advance.
var instances = ;
for(i=0; i<10000; i++){
var instance = new GeometryInstance({
geometry: new RectangleGeometry({
rectangle: new Rectangle(
CesiumMath.toRadians(west),
CesiumMath.toRadians(south),
CesiumMath.toRadians(east),
CesiumMath.toRadians(north)
attributes:{
color: ColorGeometryInstanceAttribute.fromColor(extentColor)
instances.push(instance);
var primitive = new Primitive({
geometryInstances: instances,
appearance: new PerInstanceColorAppearance(),
releaseGeometryInstances: false,
asynchronous: false
viewer.scene.primitives.add(primitive);
primitive.geometryInstances[0].show = false; //After batching, since I set releaseGeometryInstances to be false, I can do primitive.geometryInstances[0]. However, GeometryInstance doesn’t have a show property. How do I show or hide a single geometry instance?
Hi all,
I’ve found the solution. Solution is posted below just to help the folks who have similar problem.
var instances = ;
attributes:{
show: new ShowGeometryInstanceAttribute(true) //This line is important. If you skip this line, then later you can set this property to false.
asynchronous: false
//Now hide only one geometry instance from 10000 geometry instances batched into primitive.
var id = instances[0].id;
var attributes = primitive.getGeometryInstanceAttributes(id);
attributes.show = ShowGeometryInstanceAttribute.toValue(false);
在 2014年11月17日星期一UTC-8下午1时12分31秒,Steven写道:
