How to improve label font rendering, especially with border?
The rendering of labels with borders leaves something to be desired:
- The border is cropped on the left side sometimes.
- The baseline seems a bit uneven, differing from letter to letter
- Kerning is increased the wider the border is, which looks odd
To see what I mean, replace the setFont() function in https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Labels.html&label=Showcases with the code below, Run the demo, and select setFont.
    function setFont() {
        Sandcastle.declare(setFont);
        viewer.entities.add({
            position : Cesium.Cartesian3.fromDegrees(-75.1641667, 39.9522222),
            label : {
                text : 'Philadelphia',
                font : '24px Helvetica',
                fillColor : Cesium.Color.WHITE,
                outlineColor : Cesium.Color.BLACK,
                outlineWidth : 4,
                style : Cesium.LabelStyle.FILL_AND_OUTLINE
The result looks like this: https://www.dropbox.com/s/2cubixlwq7u44r0/cesium-philadelphia.png?dl=0
You can see some border cropping on the left edge of most of these letters. The baseline difference is visible here though subtle. The kerning issue is less apparent but a label like "Karachi, Pakistan" makes those more apparent: https://www.dropbox.com/s/0nq9egqh110ghep/cesium-karachi.png?dl=0 -- check out the segment "kist" -- bleh!
Is there any work being done on this, or fonts or settings that work better?
There’s some improvements in a branch, check out #2549 for details.
Patrick
Cool will do!
