I have to get the range of the camera to 3d terrain for some functions (create labels, get radius, etc).
The problem is that if I use “camera.pickRay” too early (usually at startup) I get an error
TypeError: Cannot read property ‘x’ of undefined
at Function.a.subtract (https://cesiumjs.org/releases/1.61/Build/Cesium/Cesium.js:472:14500)
at Function.a.distance (https://cesiumjs.org/releases/1.61/Build/Cesium/Cesium.js:472:13973)
at Object.get range [as range] (http://localhost/360WebApp/src/map/cameraController.js:50:34)
at getLabelsFromGeoDB (http://localhost/360WebApp/src/map/labelsController.js:52:40)
at http://localhost/360WebApp/src/map/labelsController.js:21:5
at r.raiseEvent (https://cesiumjs.org/releases/1.61/Build/Cesium/Cesium.js:471:17744)
so, I should get an event or something like that when the 3d terrain is ready
/// Return the Cartesian3 point that is the intersection
/// of a ray from the camera to the specified x and y canvas positions
/// and the 3d terrain
function getPointFromCamera(xCanvas = null, yCanvas = null) {
const canvas = viewer.scene.canvas;
if (xCanvas === null || yCanvas === null) {
xCanvas = canvas.clientWidth / 2;
yCanvas = canvas.clientHeight / 2;
const ray = viewer.camera.getPickRay(new Cesium.Cartesian2(
Math.round(xCanvas), Math.round(yCanvas)
return point = viewer.scene.globe.pick(ray, viewer.scene);
I need to pick the coordinates in the center of the frame and get the camera range as soon as possible
to create labels around that point
1.61
