var viewer = new Cesium.Viewer("cesiumContainer");
var imageryProvider = new Cesium.GeoTiffImageryProvider({
url: './output300.tif'
viewer.imageryLayers.addImageryProvider(imageryProvider);
But I can not load tif imagery,Even if I upload the image to cesium ion, it’s useless, and according to the example code provided by cesium ion, the browser won’t display anything:
I am having the same issue. I’m also trying to add an imagery (tif) to my code, manually and with cesium ion, but no luck. Anyone know how to solve this???
Would it be possible to provide a code snippet that demonstrates that. When i upload the tiff file on Cesium Ion, I get a code snippet like the one below:
However, when I add it to my file, it doesn’t work. What else in the code file do I have to add. It would be great if I could know as I can’t find it elsewhere. Thank you!
Okay I added that, and changed the asset ID accordingly based on the geotiff’s i have uploaded on cesium. I don’t get any errors, but I don’t see any output either. Not sure what the issue is.
I’ve had a similar issue recently and ended up converting my geotiff data to a gltf in QGIS with the “QGIS2threejs” plugin and then directly displayed the gltf in cesium as entity. The only downside was, that the rotation of the gltf was a bit off, so I had to rotate the 3d model, but besides that it solved my problem.
